What's the best way to level bed to use the Kraken from E3D? July 04, 2017 10:14AM |
Re: What's the best way to level bed to use the Kraken from E3D? July 05, 2017 12:03PM |
Re: What's the best way to level bed to use the Kraken from E3D? July 05, 2017 01:51PM |
Re: What's the best way to level bed to use the Kraken from E3D? July 05, 2017 09:35PM |
Re: What's the best way to level bed to use the Kraken from E3D? July 06, 2017 01:19AM |
Re: What's the best way to level bed to use the Kraken from E3D? July 07, 2017 07:48AM |
Re: What's the best way to level bed to use the Kraken from E3D? July 09, 2017 06:19PM |
Re: What's the best way to level bed to use the Kraken from E3D? July 10, 2017 12:08AM |
Origamib
I suggest you choose one to be the primary nozzle that is only used on the first layer (raft if necessary) and the other 3 have an ever so slightly higher Z height to avoid dragging through layers. Invest in some accurate shims.
Re: What's the best way to level bed to use the Kraken from E3D? July 14, 2017 09:46AM |
