incorrect hotend temperature reading July 31, 2017 12:23PM |
Re: incorrect hotend temperature reading July 31, 2017 01:02PM |
Re: incorrect hotend temperature reading July 31, 2017 01:46PM |
Re: incorrect hotend temperature reading August 17, 2017 07:17AM |
Re: incorrect hotend temperature reading August 17, 2017 07:23AM |
Re: incorrect hotend temperature reading August 18, 2017 10:44AM |
Re: incorrect hotend temperature reading August 19, 2017 12:45AM |
cwaa
I am not trying to start an argument, but two years ago I was trying to decide what hot end to put on my new printer. I chose the Prometheus. I have yet to have it clog or jam. I am now printing in two colors with it as well.
Re: incorrect hotend temperature reading August 24, 2017 05:20PM |
waitaki
cwaa
Not sure that's gonna help the original poster!
Re: incorrect hotend temperature reading August 24, 2017 06:21PM |
Re: incorrect hotend temperature reading August 24, 2017 07:49PM |
waitaki
I guess you are using PLA? I make my own hot ends based on the E3D design - with some differences but.. I print mainly in ABS.
PLA can cause havoc in many types of hot-end and I wouldn't be surprised if the Prometheus has its problems also -not that I would know. If I use PLA, I am very concious of the fact that it can't be left hanging around in the heater block. To this end, I get the heated bed up to temp(60C), load the gcode and then, finally, switch on the heater for the hot-end (185C). As soon as its at temp, I would do a quick 10-20 mm prime then immediately start the print.
I don't go above 185C or "oil" the filament, and I don't bugger about with retraction. Having said that, I am told that some PLA needs a higher temp but the stuff I have bought works best at 185. I've had my problems with PLA but usually I can make it work ok. I certainly don't like the stuff much though, that's for sure.
