FLSUN Kossel Building Tips and Problems September 02, 2017 07:52PM |
Re: FLSUN Kossel Building Tips and Problems September 20, 2017 02:15PM |
Re: FLSUN Kossel Building Tips and Problems November 13, 2017 11:18AM |
Re: FLSUN Kossel Building Tips and Problems November 13, 2017 04:52PM |
Re: FLSUN Kossel Building Tips and Problems November 13, 2017 06:27PM |
Re: FLSUN Kossel Building Tips and Problems November 14, 2017 01:52AM |
Re: FLSUN Kossel Building Tips and Problems November 14, 2017 02:01AM |
Re: FLSUN Kossel Building Tips and Problems November 14, 2017 11:27AM |
number40fan
What color are they? Have any pictures?
Re: FLSUN Kossel Building Tips and Problems November 14, 2017 04:48PM |
Re: FLSUN Kossel Building Tips and Problems November 14, 2017 10:45PM |
number40fan
I was asking about the drivers to help identify them. .25v seems really low, but if they work....
Re: FLSUN Kossel Building Tips and Problems November 15, 2017 01:05AM |
Re: FLSUN Kossel Building Tips and Problems November 20, 2017 05:55PM |
Re: FLSUN Kossel Building Tips and Problems November 20, 2017 06:09PM |
Re: FLSUN Kossel Building Tips and Problems July 08, 2018 01:37AM |
Re: FLSUN Kossel Building Tips and Problems July 09, 2018 04:59PM |
aflactheastronaut
Oh wow, I forgot I started this thread. It's been a while, and I'm happy to hear that you've solved a bunch of problems DLC!
As for me, I found some of the documentation that I was looking for in the original post. It was on the SD card that came with the printer, and I just hadn't looked for it there. Oops.
I've made it through half a spool of PETG, which has its ups and downs. It needs to print at 230+ C, and my hotend (with a ton of ceramic insulation and kapton tape) can barely stay above 235 with the cooling fan at 80%. I think the insulation just gets bad after a while, because it was holding 245 easily when I put it on the first time. More experimenting!
About your linear rail comments: I also had some issues with mine, where they would take extra force to move around. I ended up getting Slick 50 One Lube and generously applying it to the rails, and now they're smoother than butter! I'd recommend it, it was only $6. Someone else on this forum recommended it to me, since it has ptfe in it.
I have noticed my steppers getting warm, but not too bad. I did a 10 hour print last week, and they were hot enough by the end that I couldn't touch them for more than 5ish seconds. But I think my problem might just be that they're not getting any airflow and are sitting right next to the build plate/oven mitt combo, which was at 60C.
For the future, I may upgrade everything to a 24V system to let everything heat up a little faster. I'll definitely add a base to the printer to hold the power supply and controller and absolute mess of wires and some fans to cool it all. I also might upgrade to a (1.75mm) V6 extruder to see if that helps my heating issues. But it's printing alright for now, so I'm going to finish my Saturn V (https://www.thingiverse.com/thing:45316) which, btw, can be scaled 2.5X! Toodles and thanks for all the help you guys!
May your lines be straight and your extruders never clog,
Alex H
Re: FLSUN Kossel Building Tips and Problems July 09, 2018 05:37PM |
Re: FLSUN Kossel Building Tips and Problems July 09, 2018 06:17PM |
I have a custom end effector that I printed for my v6. There are plenty of them on Thingiverse. Mine does not have a bed detector, I manually level my beds.Quote
aflactheastronaut
Yeah, I'll be keeping a closer eye on my rails from now on.
Also, how close of a fit is the V6 hotend? I was looking into other effectors because I thought the stock one couldn't hold a V6.
Thanks,
Alex
