"bottom-up builds no longer supported"
March 31, 2011 08:44PM
My reprap (Mendel) seems to be fully functional EXCEPT that after starting a print it outputs "Producer.produce(): bottom-up builds no longer supported." and claims to have finished printing! I've taken a look at the code (shown below) and I'm rather confused, repraps are additive aren't they?
if(Preferences.Subtractive())
			produceSubtractive();
		else
			if(layerRules.getTopDown())
				produceAdditiveTopDown();
			else
				Debug.e("Producer.produce(): bottom-up builds no longer supported.");
				//produceAdditiveGroundUp(gp);
After some more code searching I can't find any code that does anything meaningful with the topdown variable.
Can anyone help?
Thanks
Edited 1 time(s). Last edit at 03/31/2011 08:45PM by Tomme.
Re: "bottom-up builds no longer supported"
April 01, 2011 04:39AM
I think it has to do the calculations from the top down so it can calculate where support material is required, even though it actually builds from the bottom up.
April 01, 2011 05:12AM
Any idea what I'm missing, or why it is throwing up that error?
February 18, 2012 08:50AM
Someone found already a solution for the problem with the
"Producer.produce(): bottom-up builds no longer supported"
error message?
I just got it and I'm trying to get rid of it.
But I'm running out of ideas what to do next...
February 18, 2012 05:56PM
Can you post the whole code, or link to it?
February 19, 2012 02:08PM
What host s/w, slicer, and firmware are you using?
February 20, 2012 03:17AM
Hi!
I'm using the Gen3 Electronic and the reprap 64bit-mendel-20100719 - host software & firmware.
My system is a Windows 7 64bit with the Java JRE 5.22 update
First I suspected the Java but I tried different version of it and with the java6 it is not working at all.
So I think it is the firmware because I also have some problems with the communication of the electronics. A really troublefree communication (e.g. constant display of the temperature in the debug mode is just there at the first time of operation after uploading the firmware)
But everthing else seems to work fine.
I will post the whole code in the evening when I'm home again...
Thank you!
-Dave
February 22, 2012 04:47PM
That looks to be ancient firmware. try marlin or sprinter, and i'm sure you'll have better luck
February 23, 2012 03:44AM
According to the wiki List of Firmware page neither Marlin nor Sprinter support the Gen3 electronics!
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
February 23, 2012 10:14AM
ok then try teacup. or even a 5d from 2011.
And don't use the reprap host. use literally anything else.
February 23, 2012 10:46AM
Is use FiveD 20100826 without any problems with the Gen3 electronics.
"Never change a working system!"
or
If it ain't broke, don't fix it!
Bob Morrison
February 23, 2012 11:04AM
Hah! This is reprap, after all :-)
February 25, 2012 05:49AM
Ok. It is working now!
It is printing! Still without material but the autmatic movements are pure joy for me!
I tried so many things but I think the failure was the wrong directory of the software. Shame on me.
I overlooked all the time that I have to put the software into C\Program Files\Reprap
But I still have so many things to do.
Like the Pause and Stop Buttons. Both are not working.
February 25, 2012 06:04AM
Someone cheered too soon.
Right the next trial run was the same failure again!!!
sad smiley
February 25, 2012 08:01AM
Ok. With printing directly from the gcode it is working again.
I have no idea why...
But right now my Repstrap is plotting for his first time a layer of the test part!!!
grinning smiley
