Quieter hotend cooling fans? September 27, 2017 12:39PM |
Re: Quieter hotend cooling fans? September 27, 2017 12:48PM |
Re: Quieter hotend cooling fans? September 27, 2017 02:15PM |
Re: Quieter hotend cooling fans? September 28, 2017 12:15PM |
The use of the supplied 30mm fan and duct is highly recommended, the supplied fan has adequate airflow (4-5 CFM) and the duct is specifically designed to aim that airflow at the fins of the heatsink.
Re: Quieter hotend cooling fans? September 28, 2017 07:31PM |
Re: Quieter hotend cooling fans? September 28, 2017 08:35PM |
Re: Quieter hotend cooling fans? September 29, 2017 08:28AM |
Re: Quieter hotend cooling fans? September 29, 2017 08:31AM |
Re: Quieter hotend cooling fans? September 29, 2017 11:10AM |
Re: Quieter hotend cooling fans? October 05, 2017 11:20AM |
the_digital_dentist
A resistor or a few diodes in series will drop the fan's voltage and reduce the speed and noise level.
Re: Quieter hotend cooling fans? October 05, 2017 11:56AM |
Re: Quieter hotend cooling fans? October 05, 2017 02:07PM |
Re: Quieter hotend cooling fans? October 05, 2017 03:35PM |
Re: Quieter hotend cooling fans? October 05, 2017 10:18PM |
Re: Quieter hotend cooling fans? October 06, 2017 11:21AM |
Re: Quieter hotend cooling fans? October 06, 2017 03:18PM |
Re: Quieter hotend cooling fans? October 06, 2017 04:51PM |
Re: Quieter hotend cooling fans? October 06, 2017 07:58PM |
Re: Quieter hotend cooling fans? October 22, 2017 06:13AM |
the_digital_dentist
A resistor or a few diodes will drop the voltage and slow it down a little, reducing the noise level.
Or for about $1 you can get a small buck converter to drop the voltage an adjustable amount and tweak it until you're happy with the noise level.
