carriage wheels for 1515 extrusions? October 06, 2017 01:56PM |
Re: carriage wheels for 1515 extrusions? October 07, 2017 11:56AM |
Re: carriage wheels for 1515 extrusions? October 07, 2017 12:12PM |
o_lampe
I'd use linear rails like mgn9 instead of the 1515 towers. That way you gain a lot of printarea and the carriers can be much smaller too.
OTOH,you could probably replace the bearings in the wheels to match M4 screws.
Re: carriage wheels for 1515 extrusions? October 13, 2017 11:29PM |
Re: carriage wheels for 1515 extrusions? October 14, 2017 12:53PM |
MechaBits
I have 5x IKO 9mm Linear Guides 275mm long(ish) with dual carriages that I might not get around to using, open to offer.
Re: carriage wheels for 1515 extrusions? October 15, 2017 07:14AM |
Re: carriage wheels for 1515 extrusions? October 15, 2017 01:26PM |
dougal1957
you could check out think3dprint3d they used some mini wheels on 15x15 extrusion on there mini Kossel design they may well have some wheels spare (think they might be M3 though)
V-Wheels
Re: carriage wheels for 1515 extrusions? October 15, 2017 07:39PM |
Re: carriage wheels for 1515 extrusions? October 23, 2017 12:48AM |
Re: carriage wheels for 1515 extrusions? October 23, 2017 03:53AM |
I am using a Arduino Mega/Ramps 1.4 controller with the Reprap smart graphics controller (with SD card)
Re: carriage wheels for 1515 extrusions? October 23, 2017 07:03AM |
o_lampe
I'm glad you made it work, but the graphic LCD on a Delta usually causes stuttering steppers. If you notice any of that, you better choose the 20x4 LCD.
Maybe the Marlin guys have solved this issue, because on Repetier it is known to run smoother. So it's not only a hardware issue.
If you don't find 240mm rails, you can get 300mm and cut them to length.
But that is a good idea - Rails are stupid expensive regardless, the rollers are cheap, great for a proof of concept.|
Re: carriage wheels for 1515 extrusions? October 24, 2017 01:13AM |
Re: carriage wheels for 1515 extrusions? October 25, 2017 07:41PM |
Re: carriage wheels for 1515 extrusions? October 26, 2017 04:14AM |
Re: carriage wheels for 1515 extrusions? October 26, 2017 11:11AM |
Re: carriage wheels for 1515 extrusions? October 29, 2017 04:39PM |
