" cheap e3dv6 hotend" in the same sentence
cheap V6!
"or could it be that the cooling of the hotend is bad,"
possible you checked to see if its blowing air onto the HE, not be first to reverse wire a fan.
hotend come with shroud? always help directing the air flow
you measured to see if the extruder moves 10mm of filament when asked,
whats your retraction setting could be you retracting to much.
first thing I do is confirm am not under extruding as affa mentions
increase temp to 210C " pla I assume
do the 50mm bridging test of thingiverse
tweak the retraction. drop to .8 it be stringy but it exclude retraction if it jams again
and i've set the right nozzle orifice in the slicer
the hotend comes with a liner through the heatbreak.? all metal china made are naff you need the liner type.. else polish it.
Edited 1 time(s). Last edit at 11/13/2017 03:31AM by jinx.
