Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 19, 2017 01:13PM |
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 19, 2017 02:59PM |
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 19, 2017 03:02PM |
. Also 15Kg spread over 3 screws is only 5Kg which is bu**er all for an 8 or 10mm screw. Use fine lead screws say 1 or 2 mm. That'll mean single start threads so the pitch will be the same as the lead. This will do 3 things for you. Firstly, the finer pitch will mean that you need less torque to lift the bed. Secondly, the shallow helix angle will mean that the bed will stay put without needing to apply breaks to the motors. Thirdly, you will actually be able to use layer heights that are multiples of 0.1mm without having to rely on micro stepping for positional accuracy (as is the case with those God awful 8mm lead (4 start, 2mm pitch) screws that people will insist on using for their Z axes (sorry but it's a pet hate of mine).|
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 20, 2017 03:28AM |
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 20, 2017 04:12AM |
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 20, 2017 12:54PM |
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 20, 2017 01:50PM |
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 20, 2017 01:53PM |
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 20, 2017 03:58PM |
SplatHammer
A poster on another thread wrote as if the brake could be engaged by the software after lowering the bed a step. I was dubious so thanks for confirming my suspicions! : )
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 20, 2017 04:08PM |
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 23, 2017 07:56AM |
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 23, 2017 07:58AM |
Re: Heavy 15Kg bed + ball screws = problems with Z axis motor holding? November 23, 2017 08:00AM |
