Best Chemical to Clean Hairspray off Glass Bed? December 02, 2017 07:07AM |
Re: Best Chemical to Clean Hairspray off Glass Bed? December 02, 2017 08:39AM |
Re: Best Chemical to Clean Hairspray off Glass Bed? December 02, 2017 04:32PM |
Re: Best Chemical to Clean Hairspray off Glass Bed? December 03, 2017 11:55PM |
Re: Best Chemical to Clean Hairspray off Glass Bed? December 19, 2017 10:01AM |
Re: Best Chemical to Clean Hairspray off Glass Bed? January 07, 2018 06:17AM |
Re: Best Chemical to Clean Hairspray off Glass Bed? January 07, 2018 11:11AM |
SupraGuy
I've always just used good old dihydrogen monoxide. I take the glass to the sink and run it under the hot tap. Hairspray dissolves easily enough, so unless there's ABS residue stuck to the glass, that's always been enough to get the job done. The trickiest part is getting it dry afterwards, but a paper towel or two usually does a perfectly adequate job. Maybe once in a while a drop of dish soap, but then careful rinsing off after. I think that any soap residue would probably have undesireable consequences for print adhesion.
Of course if I'm using ABS/acetone slurry, then I need to use acetone to clean it.
Re: Best Chemical to Clean Hairspray off Glass Bed? January 07, 2018 12:33PM |
kr_
I'm printing with materials that don't require to put any chemical for adhesion on glass, like PLA or Filaflex. I only heat it up and print with a 4 mm skirt for some parts.
Re: Best Chemical to Clean Hairspray off Glass Bed? January 07, 2018 02:42PM |
Re: Best Chemical to Clean Hairspray off Glass Bed? January 13, 2018 02:01AM |
