Hi
I am done building my new printer (Hypercube Evolution/ CoreXY 300x300x300) but I can't get the heated bed to work. It's wired to work on 24V, I have a 500W PSU and thee board MKS SBASE (Smoothieboard clone), everything seems to work and the thermistor reads room temp, but as soon as I set a temperature for the bed, the fuse in the PSU breaks. I measured resistance between the cables and the soldering pads of the bed and it reads 0 ohms, which from what I read it's a bad sign. It reads 0 but then the multimeter starts to slowly go higher, usually stays around 0.8 ohm. I don't think the cables are touching at the soldering points, but also seems hard to make a mistake in manufacturing in such a "simple" device. Anything else that I can try before I spend money on another one?
This is the board I'm using [
www.aliexpress.com]
It has pads 1, 2 and 3, as well as two probing points A and B.
