Print is "banded" in the Z dimension February 17, 2018 02:31PM |
Re: Print is "banded" in the Z dimension February 17, 2018 04:32PM |
Re: Print is "banded" in the Z dimension February 17, 2018 05:31PM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: Print is "banded" in the Z dimension February 17, 2018 06:30PM |
It seems very regular, whether narrow or wide. It is kind of difficult to tell, but "eye balling" it, the banding seems pretty close to the ball screw pitch.Quote
dc42
Is the pitch of the banding constant, and if so does it match the pitch of the ballscrews? Or does the pitch increase at the top where the model gets narrower?
Re: Print is "banded" in the Z dimension February 18, 2018 02:03AM |
Re: Print is "banded" in the Z dimension February 18, 2018 02:22AM |
Re: Print is "banded" in the Z dimension February 18, 2018 08:57PM |
Re: Print is "banded" in the Z dimension February 18, 2018 08:59PM |
o_lampe
How about the connecting pulleys? Do they wobble? They look printed, maybe they fit too loose on the ballscrew shaft?
Adding some linear guides would require a lot of changes around the ballscrews too. They should be only single side supported and the ball nut should be "floating" in X&Y direction. But that's gonna be difficult with the Z-stepper at the top end. Bearings, pulleys and motor should be close together.
Re: Print is "banded" in the Z dimension February 19, 2018 03:43AM |
Re: Print is "banded" in the Z dimension February 19, 2018 02:03PM |
Re: Print is "banded" in the Z dimension February 19, 2018 04:41PM |
Re: Print is "banded" in the Z dimension February 19, 2018 05:37PM |
Dirty Steve
If not Z-wobble, this can also be caused by the bed flexing while trying to hold temp.
Re: Print is "banded" in the Z dimension February 19, 2018 10:09PM |
This thing has a 1/4" solid piece of T6 aluminum. While it isn't perfectly flat (I use a glass plate on top of it), I kind of doubt that it vibrates from heating. I have much thinner aluminum plates on other printers that don't. And, I don't use "bang bang" heating either. It is quite slow to heat up and cool down...Quote
Dirty Steve
Re: Print is "banded" in the Z dimension February 19, 2018 10:18PM |
o_lampe
I'd add the linear rails to the side where the top of the "T" shaped bed frame is. Then use the stepper as belt tensioner, too. The amount of belt-wrap around the driving pulley is quite small. Here's my version of 3 ballscrews/two linear rails/one stepper. But tensioning the belt requires to move the whole alu-bar.
[attachment 102703 ballscrews_x3.jpg]
Re: Print is "banded" in the Z dimension February 27, 2018 12:56PM |
Re: Print is "banded" in the Z dimension February 27, 2018 02:57PM |
Re: Print is "banded" in the Z dimension March 01, 2018 03:17AM |
Dirty Steve
Would not be from vibrating, the build plate can swell and contract from heating, causing your Z 0 to physically change while printing, causing upper layers to squash. This can happen with even a minor swing high and low around set temp.
Re: Print is "banded" in the Z dimension March 01, 2018 03:20AM |
orbitalair
Loosen the z thread blocks at the built plate frame.
I'd bet you are getting plate wobble from there if they are rigidly attached. Let them float in the horizontal plane and lets see what it does.
Re: Print is "banded" in the Z dimension March 01, 2018 08:46AM |
