Y axis responding to X end stop??
Posted by jllongst
February 18, 2018 01:01AM
Hi all,
I put together a folder tech 2020 and I've got it mostly working. However, the Y axis will not respond to manual inputs from repetier. What's really strange is that it will home, but if the X axis reaches the endstop first, the Y axis will stop aswell. Any Ideas?
Re: Y axis responding to X end stop??
February 18, 2018 02:26AM
What is a Folger tech 2020 exactly? Is it a Cartesian- or CoreXY- or whatnot kinematics? Did you set the right kinematics type in Repetier?
February 18, 2018 02:27AM
sounds like a short on the board, joining X and Y endstops...
Check for solder blobs around the endstop plugs
February 18, 2018 11:37AM
Solved...
The FT 2020 is a Cartesian printer.
My issue was somewhere in the firmware. I uploaded the firmware from the reprap guru, which is identical to the FT 2020. My printer now works flawlessly.
February 24, 2018 06:04PM
Look in your pins.h file for your board. If your using a ramps board XMin should be 3 and YMin should be 14.
