'Home Z' differs from 'Auto Home'
Posted by stekgreif
March 31, 2018 05:52AM
Hi everbody,
I've build my own printer using Ramps 1.4, a smart controller and the marlin 1.1.8 firmware. It almost works, but I am facing one 'last' strange problem:
Home Z:
After hitting the z endstop the printer probes for a second time with slower speed. After hitting the endstop, the nozzle is in perfect distance to the bed (as adjusted).
Auto Home:
After hitting the z endstop the nozzles drives ~1mm above the bed and stays there as 0 position. There is no slower speed probing.
Since Auto Home is called from the .gcode file; every print starts at this 1mm position -- resulting in a failed print.
I am struggeling with this problems for some days now. Does somebody have any idea? Do you need more detail?
Attached you can find the Configuration.h and Configuration_adv.h
Best.
open | download - Configuration.h (65.3 KB)
open | download - Configuration_adv.h (63.4 KB)
Re: 'Home Z' differs from 'Auto Home'
March 31, 2018 06:08AM
I had this problem when I incorrectly set the M206 command in the slicer.
Proud owner and maker of build from scratch FDM 3D printer [forums.reprap.org]
April 04, 2018 03:05PM
Thanks for your reply.
Writing and reading with M500 and M501 works in software but has not effect on the hardware.
However, I can reproduce the following behaviour:
Auto Home -> allways strange Z offset
Home Z -> no strange Z offset
Home Z -> strange Z offset
and so on (toggling)
Any ideas?
