Testing stepper motors for the 1st time with a RAMPS 1.4 - Nothing works
Posted by J3d
J3d
April 03, 2018 09:01AM
I would like to try my stepper motors and nothing seems to respond!
The RAMPS is attached to an Arduino board and connected to a power supply (both 11A and 5A).
I have installed the 3 jumpers under a DRV8825 on the X-axis and connected a stepper motor on the X-axis.
The latest version of Marlin was uploaded without error and I am using a RepRapDiscount FULL GRAPHIC Smart Controller.
On the menu I selected Prepare / Move Axis / Move X / Move 100mm and nothing happens.
I have not connected anything else on the RAMPS yet, that was to test the stepper motors only.
What am I doing wrong?
J3d
Re: Testing stepper motors for the 1st time with a RAMPS 1.4 - Nothing works
April 03, 2018 09:09AM
Connect an endstop for X and do a G28 X
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
J3d
April 03, 2018 09:41AM
I have not received my endstops yet
Can I "bypass" these?
J3d
April 03, 2018 10:55AM
I just borrowed an endstop from a friend and added it
The LED works when I actuate it by hand but the G28 X does nothing
I also plugged in the extruder on E0 with a second DRV8825 and that also does not respond
J3d
April 03, 2018 10:59AM
The hotend heats up as it should but none of the motors works
J3d
April 03, 2018 11:22AM
I checked that the wires of the motors are paired correctly and they are correct
April 03, 2018 04:46PM
Did you plug the DRV8825 shields correctly?
Reference: http://reprap.org/wiki/DRV8825 and Photo from Wiki
Edited 2 time(s). Last edit at 04/03/2018 04:48PM by Rossos.
Proud owner and maker of build from scratch FDM 3D printer [forums.reprap.org]
J3d
April 04, 2018 02:12AM
Hi Rossos,
Yes I did plug the DRV8825 correctly, thanks
There seems to be something that prevents the motors to move, perhaps a safety feature?
J3d
April 04, 2018 02:49AM
Try sending G92 X0 instead of G28 X, just in case your endstops aren't configured right ( can be tested with M119 )
Edited 1 time(s). Last edit at 04/04/2018 02:49AM by o_lampe.
J3d
April 04, 2018 03:40AM
M119 gives:
09:38:13.441 : Reporting endstop status
09:38:13.441 : x_min: open
09:38:13.445 : y_min: open
09:38:13.445 : z_min: open
09:38:13.445 : ok
is it normal?
G92 X0 does nothing to the motors and gives:
09:45:11.897 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:7200 Y:0 Z:0
09:45:11.897 : ok
Edited 1 time(s). Last edit at 04/04/2018 03:46AM by J3d.
April 04, 2018 03:50AM
Please stop trying to diagnose printer issues with the lcd, Its like trying to fix a car with the steering wheel only. You need tools and to look under the bonnet!
Connect up a control interface, preferably pronterface, but cura is also fine
Watch the main console for errors
There are very few safety features that stop X,Y or Z moving, but there are a bunch for E (hotend temp related)
But endstops are an issue
you cant move in the direction if the endstop in the direction is triggered. You also cant move -ve from the 0 location (without homing that is power on position)
If an endstop is triggered and you try to move in that direction the console will be spewing out endstop triggered messages
You can also send a M119 command at the printer which will report the current endstop status
For testing you should use the ramps test firmware
[reprap.org]
This will move all axis back and forward, no safeties no endstop checking.
It also turns the mosfet on and off, so make sure not to have anything plugged into them that will uncontrollably heat up no temperature monitoring either.
April 04, 2018 03:57AM
Ok you posted mid my reply with more info,..
Endstops are normally triggered or open
open means it can move in that direction so is fine
This leaves power or stepper wiring or driver modules or stepper motors.
You say you have stepper driver in correct way ... but please take a picture and share it so we can check.
Power... the ramp board takes 12v, some people like to put 5v into the 12v 5amp plug... this wont work. (wont damage anything)
steppers, what type of stepper motors, any data sheet?
How did you determine where the coils are?
Did you wire it so one coil is on pins 1 and 2 and the second coil is on pins 3 and 4 of the stepper connector?
Edited 1 time(s). Last edit at 04/04/2018 03:59AM by Dust.
J3d
April 04, 2018 04:14AM
I have installed Repetier-Host now...
These are the stepper motors I have: [www.aliexpress.com]
I used an ohmmeter to check the coils and there is one pair with the red/blue and the other with the green/black wires, connected to 2B/2A and 1A/1B respectively
Is that correct?
Both 5A and 11A on the RAMPS board are connected to 12V, the hotbed and hot end work, the LCD also, only the motors do not move
The stepper drivers DRV8825 are brand new
Have I missed something?
J3d
April 04, 2018 04:24AM
Here is a picture of the stepper driver on the RAMPS board
open | download - IM.jpg (156.1 KB)
J3d
April 04, 2018 05:24AM
I don't know if it matters but my RAMPS 1.4 is from Sainsmart
April 04, 2018 06:17AM
Also you might wanna check this post here: [forums.reprap.org]
Do the motors give a little "kick" when you try moving them with software? If yes: try adjusting the potentiometers.
If not: I believe you are having a hardware issue.
Which can be manufacturing defect, but not limited to:
  • RAMPS 1.4
  • DRV8825
  • Mega2560
You can check RAMPS 1.4 for short-circuiting issues. I found this guy's video on RAMPS pre-flight checks comprehensive: [www.youtube.com] (Spoilers: it's in Russian)
Also, those small aluminium heatsinks on the stepper drivers: the ones that came for my build were sitting and connecting 3 resistors because the chip was sitting lower than the resistors.
Mega2560 on itself is fragile. It can malfunction in weird places, at weird times. Better always to have a couple of those lying around.
All things considered, this can happens to anyone. Even Tom3D during his Dolly build managed to grab a defective Mega2560 board AND RAMPS 1.4 board.
April 04, 2018 06:21AM
Failing to see any issues with info provided so far
Have you set the motor current via the variable resistors [reprap.org]
also try the ramps test firmware (a few messages back)
Edited 1 time(s). Last edit at 04/04/2018 06:31AM by Dust.
April 04, 2018 07:46AM
I only recommend using the ramps_test for user, who are able to tailor their working Marlin version after running the test. ( or have a known working file at hand)
April 04, 2018 10:09AM
I had a similar problem which was traced to the current setting on the DRV8825. If the current is too high the driver will shut down. Be aware that the pot needs to be turned clockwise to reduce current (at least on my DRV8825's).
J3d
April 04, 2018 11:45AM
Thanks for your inputs
There must be something wrong with the Arduino and/or the RAMPS and/or the drivers
I therefore gave up using the RAMPS 1.4 and DRV8825 for the moment and borrowed an MKS GEN V1.4 with A4988 from a friend
That worked straight away except for the z-axis
The x-axis, y-axis and extruder are plugged directly on the board but I have 2 motors for the z-axis.
Since there is only one set of pins for the z-axis on the MKS GEN V1.4 I wired the 2 z-axis motors in series and they respond as expected but sometimes one of them does not move while the other one does which is not good at all
Should I use the spare E1 for the second z-axis motor instead?
Or wire the 2 motors in parallel?
Or increase the voltage on the driver? but to what value then?
April 04, 2018 12:18PM
Why not try the A4988 drivers on the RAMPS 1.4? eye rolling smiley
Also, since you raised a whole new subject, I can only direct you to yet another explanation by Dust on these very forums here: [forums.reprap.org]
Have a good one!
J3d
April 04, 2018 01:23PM
I tried the DRV8825s on the MKS GEN V1.4 on the x-axis (which worked with the A4988) and they do not work
Which makes me think that the DRV8825s have been damaged on the RAMPS, therefore I do not want to risk damaging the A4988s on the RAMPS
I also increased the voltage on the pot for the z-axis A4988 from 0.5 (which is was I set for all the drivers) to 0.75 and it has not solved the problem with the z-axis
The solution may be to use E1 for the second z-motor: is the only thing I have to modify in Marlin to uncomment #define Z_DUAL_STEPPER_DRIVERS in Configuration_adv.h?
April 04, 2018 02:50PM
I believe that I had read something about orienting the DRV8825 -- you cannot use the location of the trim pot, as it's opposite the A4988. Since they're unkeyed, it's possible to install the stepper driver backwards. the DRV8825 is supposed to be compatible with the RAMPS board.
J3d
April 04, 2018 02:59PM
Yes, the DRV8825 must be installed differently, I checked that before plugging them in
I can only assume that they worked originally and have been damaged after installation on the RAMPS
Is there a way to test them on their own, to see what can be salvaged?
September 07, 2020 06:32AM
I hv problem with heater and thermistor,I hv Bowden v6 hot end.on connecting pronterface noheating up ofextruder heater,error message:heating failed,system stopped,heater ID_0,pls solve my problem.all other devices work ok.all s motor and fan motor of extruded also work ok. l hv not connected endstop and bed heater.pls reply
September 07, 2020 06:39AM
mahesh joshi
Hi Mahesh, does pronterface display a temperature value other than zero? If not, then the problem lies in the thermistor cable and I suggest measuring the resistance of the thermistor with a multimeter to see what the resistance is at room temperature.
Did you set a thermister type in the firmware? (what firmware are you using anyway?).
http://www.marinusdebeer.nl/
