Y-Axis Shift - Very Puzzling April 12, 2018 07:52PM |
Re: Y-Axis Shift - Very Puzzling April 12, 2018 11:18PM |
Re: Y-Axis Shift - Very Puzzling April 13, 2018 01:58AM |
Re: Y-Axis Shift - Very Puzzling April 14, 2018 04:18AM |
Re: Y-Axis Shift - Very Puzzling April 14, 2018 02:25PM |
Re: Y-Axis Shift - Very Puzzling April 14, 2018 05:12PM |
Re: Y-Axis Shift - Very Puzzling April 14, 2018 05:34PM |
Re: Y-Axis Shift - Very Puzzling April 14, 2018 11:13PM |
Re: Y-Axis Shift - Very Puzzling April 15, 2018 01:54AM |
Trakyan
A bit off topic I know, but I've always been curious. People bash spring tensioners in belt systems, but how come everyone seems to be quite happily using spring loaded anti backlash nuts? Their effect is exactly the same, when you change direction and the other half of the nut is doing the driving, the spring can compress and you get the same inaccuracy. That and when you use them on a CNC mill (as many people do), the cutting forces themselves can compress the spring.
Re: Y-Axis Shift - Very Puzzling April 27, 2018 05:20PM |
DTolbert
Hey everybody, long time reader first-time poster and I love how insightful everybody is. I have a very custom Prusa i3 built on a P3 Steel frame, using Ramps 1.4 controller on a Mega 2560. I've been having layer shifts for a long time now specifically on my y-axis. I've been searching for months and have been unsuccessful in coming up with a solution. I originally used Marlin with Slic3r and the shift would only show up on larger prints, then I started using Repetier because I found it to be much more user-friendly and convenient with the inbuilt Slic3r slicer and the problem got much more severe. I've tried everything I can think of to fix the problem some of which are listed below.
Adjusted stepper alignment to ensure it was perpendicular to the belt
Adjusted A4988 current up and down
Adjusted acceleration and jerk to extremely low levels (250mm/s^2 and 5mm/s respectively)
Changed stepper driver
Increased cooling to stepper driver
Changed steppers to higher torque models
If anybody could help you would be a lifesaver! Thank you!
Re: Y-Axis Shift - Very Puzzling April 28, 2018 05:17PM |
Re: Y-Axis Shift - Very Puzzling June 04, 2018 04:11AM |
