Hi All,
I have built a coreXY printer with a build volume of 40x40x40. I'm using a bowden extruder. Due to the larger build volume the cable run (and bowden cable) towards the extruder flexes in a way it completely drops on the drive-belts.
Is there a solution available to prevent bending and does not affect movement? Like a steel spring or something?
Thanks!
Wouter.
