Extruders and Hot Ends – Direct vs. Bowden etc. April 22, 2018 09:18PM |
Re: Extruders and Hot Ends – Direct vs. Bowden etc. April 22, 2018 10:24PM |
Re: Extruders and Hot Ends – Direct vs. Bowden etc. April 23, 2018 02:11AM |
Re: Extruders and Hot Ends – Direct vs. Bowden etc. April 23, 2018 05:19AM |
Re: Extruders and Hot Ends – Direct vs. Bowden etc. April 23, 2018 05:26PM |
Maximum operating temperature:
A: 221 °F (105 °C);
B: 266 °F (130 °C);
F: 311 °F (155 °C);
H: 356 °F (180 °C);
Re: Extruders and Hot Ends – Direct vs. Bowden etc. April 23, 2018 07:34PM |
Trakyan
I can't pitch in much on the hotend side of things, since I've only used Mk. clones and V6 clones personally.
Trakyan
I can however pitch in on why those larger machines use direct drive though. The drawback of bowden systems is their hysteresis/backlash, this backlash is proportional to the length of the bowden tube. With a relatively small machine like the BCN Sigma, the backlash isn't too bad. On a bigger machine though, you need a longer bowden tube which means more backlash which can get out of hand. Bowden tubes also have a fair bit of friction which again gets worse as the bowden tube gets longer.
o_lampe
Before you consider direct drive, think about how it will work in an enclosed printer ( I presume Nylon also needs an enclosure? )
What is the max. environmental temp of a Titan? The stepper will heat up the Titan housing a lot, too.
o_lampe
What about remote direct drives? ( Flex3drive, Zesty Nimble )
Rossos
I like how people find extravagant ways to minimize the weight of the hotend assembly. I've seen some folks even filing down the heater block to save couple of grams.
I also find it paradoxical to file down 1g of aluminium from the heater block but keep the NEMA17 motor on the hotend assembly.
There's always a plus and minus to any kind of approach. I understand having a heavy piece of metal on a CNC because it uses lead screws to everything. But in my opinion stressing out the elastic in nature (even reinforced ones) belts with a backlash from heavy object stopping back and forth is not the right approach.
If you are going to be printing slow, you can opt for Double D's (teh pun!)
For faster speeds you should consider Bowden, or at least Lead Screws.
Rossos
For flexibles there's no way to avoid Direct, I can agree on that.
Rossos
P.S. "site:forums.reprap.org Direct Bowden" in google gives me more than 10 pages.
Re: Extruders and Hot Ends – Direct vs. Bowden etc. April 24, 2018 01:59AM |
Re: Extruders and Hot Ends – Direct vs. Bowden etc. April 24, 2018 03:25AM |
Re: Extruders and Hot Ends – Direct vs. Bowden etc. April 24, 2018 03:34AM |
