Mini_IR Z-probe pcb drawing?
April 24, 2018 04:00AM
I have to make a custom bracket to mount dc42's mini_IR Z-probe under my Delrin ball effector. I've found the distance between the mounting holes is 18.4mm, but what I'm looking for is the distance from PCB-bottom edge to center of mounting hole.
Thanks in advance
Olaf
Re: Mini_IR Z-probe pcb drawing?
April 24, 2018 02:18PM
I don't have a drawing, but at [miscsolutions.wordpress.com] you will find the following in the Appendix:
If the bottom left corner of the board is position (0, 0) then other points on the board are at the following (X, Y) coordinates, in mm:
Top right corner (24.0, 17.62)
Mounting hole centres (2.70, 14.92) and (21.11, 14.92)
Mounting hole diameter 2.8
Edited 1 time(s). Last edit at 04/24/2018 02:18PM by dc42.
