What to do about persistent cobwebbing? May 22, 2018 12:36AM |
Re: What to do about persistent cobwebbing? May 22, 2018 08:39AM |
Re: What to do about persistent cobwebbing? May 22, 2018 09:23AM |
warbunniex
Have you tried decreasing the extrusion multiplier? If enough pressure is built up in the nozzle coasting will not do much. Are you getting blobs were the filament is retracted?
If you are not getting blobs then I would say your filament is either getting printed too hot or it is possibly wet. Have you tried a different roll of pla? while i like esuns selection, i have had a little bit of inconsistency in quality.
If it is an issue with the hotend, its probably how you assembled it. Stringing can come from an improperly sealed hotend. I use thermal paste on the threads of the parts to make sure it seals well.
Re: What to do about persistent cobwebbing? May 23, 2018 04:00AM |
Re: What to do about persistent cobwebbing? May 23, 2018 02:45PM |
Trakyan
Does another spool of filament yield these same results on your printer? I would joke about the quality of chinese hotends but my printer runs one as well...
So this is an issue as of installing the new hotend? If so it is worth checking the nozzle bore and whether it is clean or has debris in there. Another thing is they could have sent you an odd sized nozzle like 0.6 or something, they're usually written on the side of the hex so it's worth checking. I imagine a smaller (or partially blocked) nozzle would cause something like this as a thinner but longer string of plastic than intended would be extruded. Another thing is for your heatsink fan, is there good airflow or is there something behind the heatsink blocking it? It could be causing the heatsink to warm up, softening the PLA inside and and making extrusion/retraction less responsive causing this sort of issue. You could also try decreasing print speed, printing fast builds up more pressure in the hotend, which results in more ooze at the end of an extrusion move. What sort of print speeds/temp are you using?
Other than that I'd suggest trying a different roll of plastic maybe, but it doesn't sound like it'll help considering the filament is working fine on another printer.
Re: What to do about persistent cobwebbing? May 23, 2018 09:34PM |
Re: What to do about persistent cobwebbing? May 23, 2018 10:13PM |
Re: What to do about persistent cobwebbing? May 24, 2018 11:58AM |
orbitalair
Dumb question. Is it REALLY retracting?
Cause this is the problem I was having, but my bowden extruder is 3d printed and was flexing, so it wasn't really extruding.
E3Dv6 clones prefer small retracts too, like 1.5-2.5mm, so you have to run the temp as low as you can within those bounds to prevent dripping, and jams.
Re: What to do about persistent cobwebbing? May 26, 2018 04:56PM |
