heatend contantly clogged
Posted by martinpaul
June 15, 2018 10:01AM
I'm working on my reprap printer, but the heatend is contantly clogged. I reduced the printing temperature from 200 to 190 degrees and that helped a bit.
I tried to print Benchy and it almost succeeded. As you can in the picture the top of the chimney failed because the heatend was clogged.
On the same picture you see the piece of filament that was clogged in the heatend. The end looks like a corkscrew. My question is:
- is the pressure on the filament too high?
- Is the heat break insufficient. In other words: does the filament gets too hot too early and is too weak to be pushed
Hopefully someone can help me.
open | download - benchy.jpg (96.1 KB)
Re: heatend contantly clogged
June 15, 2018 10:38AM
If that is how you got the filament out of the hotend you might be trying to push a 1.75mm filament through a 3mm hotend. The filament shouldn't be able to curl up like this so close to the heated part.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
June 15, 2018 11:36AM
Maybe the PTFE part in the heatbrake is lost?
July 03, 2018 01:50PM
It looks to me as if your filament is not completely contained and is folding. Show a picture of the entry to your extruder and it's exit as well.
