Rotary Print Bed on a RepRap June 24, 2018 03:04PM |
Re: Rotary Print Bed on a RepRap June 24, 2018 06:12PM |
Re: Rotary Print Bed on a RepRap June 25, 2018 07:19AM |
madmike8
That’s pretty cool. You want to give us some details?
Re: Rotary Print Bed on a RepRap June 25, 2018 09:17AM |
Re: Rotary Print Bed on a RepRap June 25, 2018 10:34AM |
. I've been sticking to shallow prints for now where the increase in height isn't noticeable. I'm not sure how to compensate for the increase in circumference although I was aware of that from the start.I think designing a part with this into consideration might be an optionQuote
Trakyan
Out of curiosity, are you doing anything to compensate for the fact that as you go further out (z axis goes up) the circumference increases? If you slicer is assuming its constant then you'd end up under extruding and the gaps between extrusion lines that aren't perpendicular to the rotation axis will get bigger which I think I can see happening in the pictures. Otherwise awesome build.
A quick and easy mod you could do is swap your gears for herringbone ones, that should help reduce some of the backlash/make gear mesh smoother.
Re: Rotary Print Bed on a RepRap June 25, 2018 11:05PM |
Re: Rotary Print Bed on a RepRap June 26, 2018 12:30AM |
Re: Rotary Print Bed on a RepRap June 26, 2018 05:03AM |
Re: Rotary Print Bed on a RepRap June 26, 2018 12:22PM |
