Hotend doesnt heat
Posted by hichamom
Hotend doesnt heat
July 02, 2018 12:51PM
hello guys i have a problem witch is the hot end of the extruder does heat at all even on Repetier-Host or Printrun
does show the initial temp
here is a screenshot
open | download - Untitled.jpg (231.7 KB)
open | download - Configuration.h (64.8 KB)
Re: Hotend doesnt heat
July 02, 2018 01:53PM
so your room temp is 738C ? man you like it hot!!!
two options. One the thermistor wires are shorted together, two the ADC on the main chip is dead.
unplug the thermistor from the controller, Does the reading change? If it does check your thermistor and wires for shorts
If not... dead controller...
July 03, 2018 01:30AM
@Dust
A shorted thermistor wire would show Min_Temp error
It could be a broken wire of the thermistor or you plugged it in a wrong port. I bet on broken wire or bad crimp job.
July 03, 2018 02:12AM
@O_lampe
No with a ntc thermistor (what reprap uses) resistance decreases with increasing temperature
a short is min resistance and therefor max temperature in the tables, and open is min temp
see [www.resistorguide.com]
and If you don't believe that, perhaps you will believe Thomas Sanladerer [www.youtube.com]
Edited 2 time(s). Last edit at 07/03/2018 02:29AM by Dust.
July 03, 2018 03:27AM
That's assuming safety features are enabled. But yeah, from my experience high temps are usually a short, check the insulation goes right up to the bead and the set screw if that's how its attached isn't too tight.
