Hot end doen't heat up no more/ hotend non si riscalda più July 14, 2018 01:04PM |
Re: Hot end doen't heat up no more/ hotend non si riscalda più July 14, 2018 02:39PM |
Re: Hot end doen't heat up no more/ hotend non si riscalda più July 14, 2018 03:25PM |
Roberts_Clif
The Hot-end Mosfet Could have gone Bad. What is your normal TPE temperature reading?
Lets test - set to preheat the nozzle can you measure the voltage across the Nozzle heater connector? Post the the voltage results.
What Controller are you currently using.
Re: Hot end doen't heat up no more/ hotend non si riscalda più July 14, 2018 05:27PM |
johnleft
"What is your normal TPE temperature reading?"--> I tried to print PTE up to 10° and bed up to 65°. First two layers was good, then the nozzle got clogged (but I'm not sure i've understand your question..)
"can you measure the voltage across the Nozzle heater connector?"--> take a look in the pic I've attached: I have to test on (1), (2) or (3)? And, multimeter on "Ohm", red on red and black on black?
I control the printer with LCD panel printing from SD card.
Thanks for your patience
Re: Hot end doen't heat up no more/ hotend non si riscalda più July 15, 2018 08:20PM |
Re: Hot end doen't heat up no more/ hotend non si riscalda più July 15, 2018 09:01PM |
Re: Hot end doen't heat up no more/ hotend non si riscalda più July 16, 2018 03:06AM |
Re: Hot end doen't heat up no more/ hotend non si riscalda più July 16, 2018 09:03AM |
Roberts_Clif
It Appears that the Hot-end Heater is 5 ohms, this is where it should measure. So I will assume that the Hot-end Heater is Good.
Now for the DC volt section measure voltage across point 1 with 2&3 Connected and Disconnected.
This will tell if you have voltage without a load and if you have voltage with a load.
Re: Hot end doen't heat up no more/ hotend non si riscalda più July 16, 2018 09:08AM |
johnleft
So, with multimeter to 20V:
2&3 plugged in:
first time 0.12.... second time 0.07... from third time on, always 0.05
2&3 unplugged:
0.05 but if I move the cables it gives me 0.08... 0.10... 0.04... 0.07... when it get fixed, is 0.05
Re: Hot end doen't heat up no more/ hotend non si riscalda più July 16, 2018 02:25PM |
