Build I3 prusa 300x300x300 August 01, 2018 12:10PM |
Re: Build I3 prusa 300x300x300 August 01, 2018 12:19PM |
Re: Build I3 prusa 300x300x300 August 01, 2018 12:34PM |
Re: Build I3 prusa 300x300x300 August 01, 2018 02:29PM |
Re: Build I3 prusa 300x300x300 August 01, 2018 10:28PM |
Re: Build I3 prusa 300x300x300 August 03, 2018 09:49AM |
the_digital_dentist
I built an i3 type machine with a 300x300 mm bed (SoM), and ended up putting in a ball screw and DSP driver in the Y axis because of the problems in controlling the bed at print speed. Mechanical resonances prevent it from moving >40 mm/sec. It has been producing quality prints almost daily for over 3 years at the Milwaukee Makerspace with very little down time, but I would not do it that way again.
I also built a coreXY machine (UMMD) with a 300x300 bed. It works much better and prints much faster. I'll soon be updating SoM with a new bed similar to that in UMMD.
Both designs are linked in my sig, below. Take a look at both designs and see if there isn't something there you can use.
I suggest you think about what you want in a printer, look at a lot of designs, then design and build your own, taking the best stuff from other designs, or creating your own. Be harshly critical of the designs you look at. Think about how things behave under nonideal - i.e. realistic- conditions. It's much more interesting than following someone else's BOM and far more educational. There are about 1000 problems to solve in each design and build and coming up with solutions to those problems is where all the fun and education lie. If you follow someone else's BOM you may as well just buy a kit and save yourself the trouble of sourcing the parts.
Re: Build I3 prusa 300x300x300 August 03, 2018 11:41AM |
Re: Build I3 prusa 300x300x300 August 03, 2018 05:49PM |
Re: Build I3 prusa 300x300x300 August 08, 2018 06:33PM |
Re: Build I3 prusa 300x300x300 August 13, 2018 09:51AM |
