Screen offset issue - Reprap discount full graphic smart controller
Posted by _matt_
November 18, 2018 02:06PM
I've been having an issue with my screen on my Reprap, it's more of an annoyance than an issue really.
After a few minutes of operation the screen will kinda shift over to the left, with the cut off part wrapping around to the right. I've attached a picture of this.
I have no idea what is causing it, fairly sure it's not marlin as I've used a few different versions with the same result. My guess is that it's a problem with my cheap hardware.
Any suggestions for solving this are welcome smiling smiley
open | download - Screenshot_20181118-185918.jpg (398.2 KB)
Re: Screen offset issue - Reprap discount full graphic smart controller
November 18, 2018 08:14PM
Maybe check that the ribbon cables are seated correctly and go from there.
November 18, 2018 10:56PM
If it's related to ribbon cable length or bad contact, it would show all kinds of different errors.
Those LCDs are all 'compatible' with a standard LCDs command code. If you happen to have a repeatable mis-function, it's likely it misinterprets one command or even ignores it.
Edited 1 time(s). Last edit at 11/18/2018 10:56PM by o_lampe.
November 19, 2018 04:12AM
loosen off the screws, they don't like to be squeezed
November 19, 2018 10:02AM
Looks to me some kind of memory offset shift that I know some displays have to shift the content of the display. If it's consistently doing that it could be a memory issue or a firmware issue. Some displays are made with customizations of other manufacturers and you've picked up a model with such a change. Try a display from a different source.
Kind regards
Imqqmi
NFAN CoreXY printer:
[reprap.org]
November 20, 2018 06:42AM
Just tried backing off the screws, no improvement
Thanks for the suggestion though smiling smiley
November 20, 2018 06:46AM
I think you may be right imqqmi, I'll source a different driver and give that a go when I get some free time.
Thank you everyone for your suggestions, I'll continue to check here if you have any others and I'll be sure to post the fix if I find one
December 01, 2018 07:34AM
Problem not yet solved?
Is this problem with marlin software, version RC7?
Try this:
Find U8GLIB_ST7920_128X64_RRD u8g(0);
you should find it in tab ultralcd_impl_DOGM.h
make backup (type // in front) and type on new line
U8GLIB_ST7920_128X64_1X u8g(23,17,16);
Compile and Upload
December 11, 2018 01:10PM
frits1956
Try this:
Compile and Upload
Worked perfectly, thank you so much
