Issues with Marlin on my Anet A8 January 30, 2019 10:21AM |
Re: Issues with Marlin on my Anet A8 January 30, 2019 02:07PM |
Re: Issues with Marlin on my Anet A8 January 30, 2019 03:50PM |
choochooboy123
Hi! I am very very new to printing, just got a printer a few days before posting this. I decided to install Marlin after watching a few videos and seeing some forums that recommend it over the stock firmware that comes with the printer. I had a few initial issues, like the stepper motors being inverted, but was easily able to fix those. Unfortunately, i cannot figure out a big issue. My z end stop switch is completely ignored. It worked before marlin, and even after digging around for hours i couldn't find a solution. Wondering if i could get some help?
Re: Issues with Marlin on my Anet A8 January 30, 2019 06:23PM |
Re: Issues with Marlin on my Anet A8 January 30, 2019 10:09PM |
Re: Issues with Marlin on my Anet A8 January 31, 2019 09:24AM |
Re: Issues with Marlin on my Anet A8 January 31, 2019 10:41AM |
obewan
Where is the z switch located ,top or bottom of ?
Make sure it is plugged into the corresponding monthly or max conector.
Re: Issues with Marlin on my Anet A8 January 31, 2019 01:01PM |
Re: Issues with Marlin on my Anet A8 January 31, 2019 05:30PM |
choochooboy123
Thanks for the info on pronterface! i never knew what software to use to interact and send gcode before this. I tried the M119 command and it said that the x and y endstops were open, but the z endstop was "TRIGGERED." None of the endstops are being pressed so I'm confused as to what to do in this case. The stops worked perfectly on it before i installed Marlin and unfortunately the software provided to flash the original firmware doesn't work.
Re: Issues with Marlin on my Anet A8 February 01, 2019 09:29PM |
Re: Issues with Marlin on my Anet A8 February 02, 2019 02:06PM |
choochooboy123
Thank you guys so much for the help! After inverting the z-axis end stop logic in the configuration.h file as suggested it finally started to work properly. As of posting this i am doing some test prints to see its capabilities. Once again, thanks for all your help.
