I am using an IR sensor based on a K type sensor.
And I notice one issue with the TC pin.
If the HB, E0 and E1 is defined as high. shown as below
digitalWrite(HEATER_2_PIN , HIGH);//main bed
digitalWrite(HEATER_3_PIN , HIGH);//feed bed
digitalWrite(HEATER_1_PIN , HIGH);//temperary
the reading of TC2 increases briefly 450
for eg: 100 (with HB, E1, E2 high) would turn to 450
If only E1 is defined as high, and HB, E0 is defined as low shown as below
the reading of TC2 is staying at 100.
the reading of the TC2 is done in under the same temperature.
So I don't really why.
PS, the IR sensor is powdered by E1, HB and E0 powers two heating sheet.
Thank you.
