Z offset question
Posted by evgeniy.romensky
Z offset question
May 20, 2019 12:17AM
Help me please, where I can configure Z offset in Marlin firmware, or I can do this in Cura slicer?Maybe in Repetier or Pronterface??
Re: Z offset question
May 20, 2019 09:11AM
In most slicers you can use the M851 - Z Probe Offset in your Start.gcode
Edited 1 time(s). Last edit at 05/20/2019 09:11AM by Roberts_Clif.
May 20, 2019 04:31PM
In marlin this can be controlled from the menu if you've got a display. That way you can adjust it without having to upload the firmware for every change. From memory, go to control, motion, z offset.
Kind regards
Imqqmi
NFAN CoreXY printer:
[reprap.org]
May 20, 2019 05:54PM
If you use Pronterface or any program that can send GCODE you can just type into the console when connected: M851 ZX.XX so Z 0.60 will be a 0.60mm offset. This can also be a negative value.
After that store the settings in the EEPROM with M500.
This video explains how this works, but it's for a BLtouch, but that doesn't matter.
http://www.marinusdebeer.nl/
