Smooth Bolts for Idler bearings's (instead of threaded screws)
Posted by Govahnator
August 14, 2019 09:36AM
Hi Guys,
My flanged bearings arrived f608zz and f636zz
[scontent-bru2-1.xx.fbcdn.net]
Now i dont want to use regular bolts, shims and nuts to make it all fit.
Some people use smooth rods with shims, wich aren't ideal either.
The proper way imo is to use pins that have to be pressed into the bearings, i am having a hard time finding the correct name for these. I found them on aliexpress as "shoulder bolts" like these [www.aliexpress.com]
And Clevis pins [www.aliexpress.com]
I am not sure if these can be pressed fit with a hammer or have play and need shims/washers.
What i would prefer to do is print a tool where a bearings clicks in, than hold that piece with the bearing inside and hit the pins through the bearings with a hammer up to the required height.
Basically i am looking for sort of smooth rod that doen't have any play.
Can anyone help me with the correct names or links of what i am looking for? Thanks!
Edited 1 time(s). Last edit at 08/14/2019 09:44AM by Govahnator.
Re: Smooth Bolts for Idler bearings's (instead of threaded screws)
August 14, 2019 10:55AM
I don’t know the name, but maybe i can offer an alternative. I resolved a similar problem with a printed part that has a hollow split shaft on which the bearing is put. The hole in the shaft was designed to expand when a screw is put in, thus fixing the bearing without any play, while the screw gave the setup the necessary stability.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
August 14, 2019 11:06AM
Shoulder screws are made to have bearings mounted on them, clevis pins are not. Also, using a hammer to drive the shaft into a too-tight bearing is a great way to quickly destroy a bearing. Bolts that have unthreaded shanks can be used like shoulder screws, but shoulder screws are made and finished better. There is going to be variation in the hole diameter in the bearings and in whatever rods or shoulder screws you use, so if you're looking for a tight fit you may have to try multiple bearings against multiple shafts/bolts to find good matches.
I wouldn't rely on a tight fit to keep the bearing captive on the shaft. Will it still be tight and captive if the temperature rises a bit?
August 15, 2019 03:12AM
Actually, shoulder bolts were not designed for bearings although many people use them for this. Most shoulder bolt shoulders are .002" to .004" undersized which makes for a very loose fit in a bearing. McMaster-Carr has precision shoulder bolts which are -.001" to 0" and would be a better choice.
August 15, 2019 12:06PM
I've seen a number of CNC plans using 608 bearings mounted on 5/16" shoulder bolts. 5/16" is 7.9375mm, so even at full size, there is a BIT of play for the bearing to sit on the bolt, but not enough to introduce any actual slop, even for fairly precise CNC tolerances, the bearing quality still makes more of a difference. Also, since the bearing is loaded, there isn't any opportunity under normal operation for that slight discrepancy to make any actual difference.
I suppose that an actual press-fit bearing might have advantages though, particularly if you don't want to have any lateral movement of hte bearing without needing to use washers or shims to keep the bearing in place. Such a fit would probably be temperature sensitive, and shouldn't really be trusted anyway, unless the tolerances are SUPER tight, in which case, swapping out hte bearings becomes problematic. Once you need a press to install or remove bearings, your bearings had better be made to withstand those kinds of forces. The inexpensive 608 type bearings that we are using for these kinds of applications are NOT made that way, you'd likely do damage tot he bearing races trying to press them into place.
August 15, 2019 04:58PM
During the design of my printer, I contemplated many of the same things.
Definitely don't use fully threaded bolts. I find that no matter how close the outer diameter of the bolt is to the inner diameter of the bearing that they're still not perfect and there's some play there. Then the bearings chatter on the bolt. Plus you're playing a game of putting a nut or spacer up against the inner hub of the bearings. If you tighten them to remove the chatter then they don't spin. I also saw that the bolts would actually eat into the bearing, creating threads and metal shavings to fall down on other moving parts of my printer.
Something like a smooth rod would be better, the problems I found are is that generally whatever diameter smooth rod doesn't fit into the bearing with the same diameter because of their tolerances. I never thought to try, but you could try finding a smooth rod that just barely doesn't fit your bearings and throw it in the freezer. See if the cold has shrunk it enough to slide the bearing on it. Position it where you want and let it warm back up. That could lock the bearing in place. Though you're kind of stuck if you ever want to change it.
I didn't think about Clevis pins, I could see the same thing happening with the bearings chattering though,
Without having to machine some crazy custom part, The only real solution I found was this:
Basically took the rotational movement away from the pulley. I used mounted bearings with set screws, a d-shaft with a flat and a pulley to fit.
Edited 1 time(s). Last edit at 08/15/2019 04:59PM by blt3dp.
My 3D Printing YouTube Channel
Better Living Through 3D Printing
Follow me on Instagram and Twitter
Instagram
Twitter
August 15, 2019 05:57PM
I had a piece-o-junk from something I took apart years ago with two 1/4" bearings press fit into it. I needed to make an idler pulley for the Y axis in one of my printers and discovered that an off-the-shelf 20 tooth GT2 pulley fit perfectly between the bearings. IRIC, I put two small washers on either side of the pulley to ensure that it could only contact the inner rings of the bearings. I had a 1/4" shaft from some other piece of junk I took apart.
August 16, 2019 02:29AM
With ball bearings, the fixed part doesn't need to be a tight fit only the moving one. In fact it is better if it isn't as it makes assembly/disassembly easier and allows thermal expansion.
Refer to manufacturer doc for details. No need to invent wrong or unnecessary complex mount.
Here for the regular idler found in 3D printer, the bearing is and must be a tight fit in the pulley but not the shaft. Play should be minimal, less than 1/20 to reduce wobbling. Blue Loctite can be used to reduce it without making a tight bond.
Of course threaded rod are not suitable. 4, 5 mm smooth rods are common. Just in case, plenty to be found in old printers, scanners.
On a stepper motor, the bearings are a tight fit on the shaft but not in the body.
Edited 2 time(s). Last edit at 08/16/2019 02:33AM by MKSA.
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
August 16, 2019 11:36AM
the_digital_dentist
Nice little Bearing Block pity about them screws.
August 16, 2019 02:07PM
Them screws is OK. The conical surface of the screw heads helps center the whole part to keep it aligned.
August 17, 2019 12:42AM
I'd have to print some covers...on the topic, I've used 8mm rod's 8mm shoulder bolts both work great, and some other 5mm shoulder type bolts(partially threaded) having to match the bearing on that was the trickiest but I think its fine.
August 17, 2019 02:55AM
I was pondering last night about spring pins, using a close fitting clevis or yolk with the same size holes to contain the bearing and pin. They're basically a spring steel tube with tapered ends made to drive into a dowel hole, but hold with outward spring tension instead of adhesives or an interference fit.
Untried, but a thought none the less.
It doesn't take a great deal of force to insert a spring pin, so unlikely to damage the bearing.
Probably not useful for a one sided mount.
Edited 3 time(s). Last edit at 08/17/2019 03:11AM by Diggrr.
August 17, 2019 03:27AM
Diggrr
Why don't you simply read some doc about ball bearing use and assembly ? There are simple rules, don't follow them and for sure get funny problems later that you will spend time figuring out.
August 17, 2019 05:42AM
Spring pins may well work with bearings but the following things may cause problems:-
  • Spring pins are quite badly formed in terms of circularity and might force the inner race out of circularity causing tight spots.
  • Both the bearing and the hole(s) in which the pin mounts should be very close in size as the pin shrinks to fit the smallest one
Otherwise, it sounds like quite a good idea - please report back if you try it out.
Mike.
August 17, 2019 04:32PM
etfrench
What were shoulder bolts designed for?
August 19, 2019 10:58AM
cozmicray
etfrench
Indeed, one of the purpose is for bearing, hinge ....
But the topic of this discussion is to avoid the use of the proper standard readily available "shaft" like smooth rods (OK, you need to cut it to length) with Loctite if and where needed (on the rotating part) or shoulder bolt ! smiling smiley
