Drilling Plate August 18, 2019 08:29PM |
Re: Drilling Plate August 18, 2019 09:24PM |
Re: Drilling Plate August 18, 2019 11:09PM |
Re: Drilling Plate August 19, 2019 02:11AM |
ders
.. This is probably an elaborate excuse to stick to the standard build plan. Is using a four-point design that flawed? I see you have experience with this nature of plate. Do you think I should convert to three screws, and if so why would you suggest that they be placed at the midpoints of three sides of the plate rather than two adjacent corners and the opposite side's midpoint?
Is that to say that I should just drill holes, not slots, and not worry about tapping them?
Re: Drilling Plate August 19, 2019 09:43AM |
Re: Drilling Plate August 19, 2019 07:43PM |
MKSA
BTW, there are other bolts than M3 !
Re: Drilling Plate August 20, 2019 06:48AM |
Re: Drilling Plate August 20, 2019 08:18AM |
Re: Drilling Plate August 20, 2019 11:49AM |
Re: Drilling Plate August 22, 2019 10:05PM |
the_digital_dentist
If you want to make a kinematic mount, one slot is needed.
Making your own bed heater is risky business. If the wire gets too hot it will burn through the kapton. The adhesive on the kapton may not be able to withstand the peak temperatures reached. Good luck.
Re: Drilling Plate August 23, 2019 05:05AM |
Re: Drilling Plate August 23, 2019 07:50AM |
Re: Drilling Plate August 24, 2019 05:27AM |
Re: Drilling Plate August 24, 2019 08:56AM |
leadinglights
In order to level the bed, it is only necessary to set the distance in the Z direction from the bed to the nozzle above each of the mounting points - it is not necessary either to have a reference datum nor to set the other mounts on the X or Y axes relative to the reference.
Edit. As long as the bed starts less than a couple on mm off level it is only necessary to adjust the screw to set the nozzle to bed gap just once at each of the three positions - this will not affect the other adjustments.
leadinglights
The final position of the mounts differed from being 120° apart by less than 2° and the radial distance from the common centre by less than 8mm. The effect of these, both theoretical and practical, is insignificant.
Re: Drilling Plate August 24, 2019 11:10AM |
Re: Drilling Plate August 24, 2019 01:30PM |
Re: Drilling Plate August 24, 2019 04:03PM |
MKSA
Besides, let's not forget that these machines are just spitting molten plastic. +- 1/20th is good enough.
Re: Drilling Plate August 24, 2019 05:00PM |
