Hello, I'm having a big problem, I bought a MKS GEN l 1.0 card because the original board of my anet a8 gave problem, until then ok, I downloaded marlin 1.1.9 and made some changes to work correctly on the board and when I went to test the engines did not work (I thought it was the driver (DRV8825) I changed and still did not work so I thought it was the faulty engine but when I put in another board the engines work normally, I managed after a lot of effort to make them "work" on the board mks gen L 1.0 but only in one direction on x and y axis already in z it works in both directions even in marlin is set up like this
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR true
#define INVERT_Y_DIR true
#define INVERT_Z_DIR false
NOTE The motors "run inconsistently on the mks board, and even if not moving they emit a strong" beep "the drv8825 vref is sized correctly for this engine, I put 0.6 in the trimpot
all hardware from extruder table motor is original from anet a8
Edited 1 time(s). Last edit at 08/30/2019 07:20PM by kilzone0007.
