Belt width CoreXY - 6, 9 or 12mm? January 21, 2020 02:25PM |
Re: Belt width CoreXY - 6, 9 or 12mm? January 21, 2020 05:53PM |
Re: Belt width CoreXY - 6, 9 or 12mm? January 23, 2020 02:10AM |
the_digital_dentist
Deckingman moves around about 3kg of X axis in his printer using 6mm belts. I use 9mm belts. I don't think it matters much.
Whatever you do, don't use steel core belts- they require very large pulleys. If you use "normal" size pulleys the steel wires will break inside the belts and then the polyurethane will stretch over the wires and you'll have all sorts of weird print quality problems.
Re: Belt width CoreXY - 6, 9 or 12mm? January 23, 2020 11:17AM |
Re: Belt width CoreXY - 6, 9 or 12mm? June 28, 2020 12:52PM |
Re: Belt width CoreXY - 6, 9 or 12mm? June 28, 2020 05:07PM |
Re: Belt width CoreXY - 6, 9 or 12mm? June 28, 2020 05:50PM |
Re: Belt width CoreXY - 6, 9 or 12mm? June 28, 2020 09:38PM |
Re: Belt width CoreXY - 6, 9 or 12mm? June 29, 2020 03:35AM |
Re: Belt width CoreXY - 6, 9 or 12mm? June 29, 2020 07:09AM |
