Snappy Help
February 02, 2020 05:56PM
Hi, new to the forum. My son is building the snappy rep rap, he has it all printed and put together and everything is ready. We are running into a problem trying to get marlin software to compile. We just keep getting error codes and it won't finish. I am new to all of this and not sure where to turn next, we just followed the links off of wiki. If anyone could help point me in the right direction it would be much appreciated.
VDX
Re: Snappy Help
February 02, 2020 06:21PM
... what's the board, Arduino and Marlin version?
Viktor
Re: Snappy Help
February 02, 2020 06:36PM
Using mega 2560 board
Arduino 1.8.6
Marlin snappy 1.1.x
Thanks
Re: Snappy Help
February 02, 2020 07:33PM
and how about an error message to give us a clue?
Re: Snappy Help
February 02, 2020 08:12PM
Collect.exe: error: 1d returned 1 exit status
Exit status 1
error compiling for board arduino/genuino mega or mega 2560
Re: Snappy Help
February 02, 2020 09:26PM
full log of compile please
Re: Snappy Help
February 03, 2020 07:55AM
Heres the link to what we are using, hopefully this helps. I can try and get more info if you need it. Thanks
[github.com]
Re: Snappy Help
February 03, 2020 08:33AM
I Downloaded this "Marlin-snappy-1.1.x" an found this which is the same with more information "snappy-reprap-snappy_3.0.3"
They both compile with these results using Arduino 1.8.8 Mega 2560 and AVRISP mkll programmer
Sketch uses 107744 bytes (42%) of program storage space. Maximum is 253952 bytes.
Global variables use 3407 bytes (41%) of dynamic memory, leaving 4785 bytes for local variables. Maximum is 8192 bytes.
They include compiled Hex code files to directly upload to controller.
Marlin.ino.with_bootloader.mega.hex
and
MarlinRampsNoLCDNoHBP.hex
MarlinRampsRRDFullGraphicSmartCntrlrNoHBP.hex
Edited 2 time(s). Last edit at 02/03/2020 08:39AM by Roberts_Clif.
Re: Snappy Help
February 03, 2020 09:36AM
Thanks we'll give it a try!
Re: Snappy Help
February 04, 2020 05:27PM
Be sure to use the newest Arduino compiler/IDE otherwise lots of weird library errors are likely to occur.
DLC
Kits: Folgertech Kossel 2020 upgraded E3Dv6, Anet A8 upgraded E3Dv6, Tevo Tarantula enhanced parts and dual-head, TronXY X5SA Pro(E3DHemera).
Scratch: Large bed Cartesian, exchangeable heads, Linear slide Delta, Maker-Beam XL Micro Delta, 220x220CoreXY.
Re: Snappy Help
February 04, 2020 07:23PM
Will do, we haven't been home last couple of days to give it a try. No one has a link to video for this by chance do they? I found a ton of videos on building the snappy but nvere anything for the software part of the build.
