I run Marlin on a DIY reprap i3 cartesian printer which I built and ran successfully several years ago. I upgraded recently to Marlin 1.1.9(bugfix) which I configured with Arduino IDE 1.8.10. All functions worked correctly including the nozzle offset (-38 mm) as my X axis is wider than the bed.
I then decided to add a BL Touch sensor for Automatic Beb Levelling. The sensor is offset X by -45 mm (left) and Y by 8mm (behind) which I think is correct. When I then compiled the modified Marlin firmware I get the following sanity check:
static assertion failed: RIGHT_PROBE_BED_POSITION is outside the probe region.
I have tried changing the BL Touch offset to zero and to a +ve integer but I still get the same message. Is this a bug or is it some error on my behalf? I have seen this error mentioned on GitHub but as a non programmer I have failed to see any resolution. I would be grateful for any advice if anyone has experienced and solved the problem. My configuration.h is attached,
TerryD
Edited 1 time(s). Last edit at 02/03/2020 05:22AM by TerryD15.
