I am running a Mega 2560 / RAMPS 1.4 stack using a
24V setup:
1. Remove D1, power the mega via the 2.1mm center-positive DC jack, The recommended range is 7 to 12 volts.
I have cut D1, and the 12V is produced using a 24-12V buck converter.
While the two boards are connected there is continuity from the Mega DC jack V+ to RAMPS GND. This is with nothing else connected; just a large sink on the Mega which does not touch anything.
Is there any way of knowing which components are causing this? Is there a higher chance of it being one of the two boards?
Since I discovered this by nearly popping the 3A buck converter with everything plugged in, I guess the Mega is fried? But the [potential culprit] RAMPS lives on?
I suppose I might want to order both state-side. Has anyone else had a similar experience?
EDIT: My friend gave me a MKS Gen 1.4 and the printer runs on it. I'm using the LCD that came in the same kit as the boards though... the thing doesn't drive correctly and has a pixel offset; barely legible yet hideous. Bad electronics...
Edited 1 time(s). Last edit at 02/08/2020 12:33AM by ders.
