Stepper motors vibrate, turn one way, then the other February 18, 2020 12:28AM |
Re: Stepper motors vibrate, turn one way, then the other February 18, 2020 01:13PM |
Re: Stepper motors vibrate, turn one way, then the other February 18, 2020 01:56PM |
Re: Stepper motors vibrate, turn one way, then the other February 18, 2020 05:41PM |
Re: Stepper motors vibrate, turn one way, then the other February 19, 2020 12:35AM |
dlc60
Well, you've changed everything but the wires, and the power supply. Check to see that you are getting the voltage (12 or 24V) that you should be at your controller board. Low voltage will cause a stepper to be "weak" and may cause your issue.
DLC
Re: Stepper motors vibrate, turn one way, then the other February 19, 2020 02:47AM |
Re: Stepper motors vibrate, turn one way, then the other February 19, 2020 11:34PM |
dc42
Sound like only one phase of the stepper motor is being energised. If it's happening on just one driver, probably due to a bad connection or faulty driver. If it's happening on all drivers, probably a bad power input connection.
Re: Stepper motors vibrate, turn one way, then the other February 24, 2020 04:54PM |
