struggling to set correct bed size May 03, 2020 04:46PM |
// The size of the print bed #define X_BED_SIZE 220 #define Y_BED_SIZE 220 // Travel limits (mm) after homing, corresponding to endstop positions. #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0 #define X_MAX_POS X_BED_SIZE #define Y_MAX_POS Y_BED_SIZE #define Z_MAX_POS 600
Re: struggling to set correct bed size May 03, 2020 04:55PM |
Re: struggling to set correct bed size May 03, 2020 06:10PM |
Re: struggling to set correct bed size May 03, 2020 06:25PM |
Re: struggling to set correct bed size May 03, 2020 07:07PM |
// #define MAX_SOFTWARE_ENDSTOP_X // #define MAX_SOFTWARE_ENDSTOP_Yand it seems to be working.
G1 X0 Y0 G1 X100 Y100 G1 X220 Y220
#define NOZZLE_TO_PROBE_OFFSET { 0, 80, 0 } #define MIN_PROBE_EDGE 25
Re: struggling to set correct bed size May 04, 2020 04:10AM |
* * - AUTO_BED_LEVELING_BILINEAR * Probe several points in a grid. * You specify the rectangle and the density of sample points. * The result is a mesh, best for large or uneven beds. *
Re: struggling to set correct bed size May 04, 2020 05:01AM |
#if EITHER(MESH_BED_LEVELING, AUTO_BED_LEVELING_UBL) // Override the mesh area if the automatic (max) area is too large //#define MESH_MIN_X MESH_INSET //#define MESH_MIN_Y MESH_INSET #define MESH_MAX_X X_BED_SIZE - (MESH_INSET) #define MESH_MAX_Y Y_BED_SIZE - (MESH_INSET) #endif
#if EITHER(MESH_BED_LEVELING, AUTO_BED_LEVELING_UBL) // Override the mesh area if the automatic (max) area is too large #define MESH_MIN_X 25 #define MESH_MIN_Y 5 #define MESH_MAX_X 220 #define MESH_MAX_Y 140 #endif
Re: struggling to set correct bed size May 04, 2020 08:14AM |
