i have a weird problem with extruder. extruder ckicks and reverse direction for itself.
some things that i have tried:
1-i thought the stepper or driver is broken or have problems.so i did stuff to make sure both stepper and driver is fine, which both was fine.
2-checked whole extruding system...it was fine
3-i calibrated extruder driver voltage...not helped
4-i changed E0 and E1 pins in marlin and connected extruder into E1....and problem solved.
thats right problem solved ,but it is annoying me ,and i saw many ppl suffering from this problem
i bought another ramps 1.4...same problem.and same solution worked.
i bought ramps 1.6...same problem and same solution worked.
the only thing is im not sure is marlin
does anyone knows what is the problem? i need help
