RAMPS Question
Posted by bajasam96
RAMPS Question
June 19, 2011 12:29PM
So I started putting together the electronics while I wait for parts to arrive in the mail. I will be using the Pololu drivers with an arduino combo. It all went together pretty slick, except the reset button. I wanted it to the same button as what would be on the Mega as it will be right on top of it, but the PCB board appears to need a single pole switch and the arduino uses a dual pole switch...
My real question is- for the reset switch, were only connecting "1" to "2" on the PCB correct? in which case my switch can do that fine.
Thanks in advance
Re: RAMPS Question
June 19, 2011 02:33PM
The pin pattern won't match up, but yeah, itwill work.
Re: RAMPS Question
June 19, 2011 05:44PM
I Hate to nit pick,
But your Polo Drivers appear to have pins poking out the tops,
Mine are coming out the other side leaving the IC & trim pot accessible,
and mine do work!
Rob
Re: RAMPS Question
June 19, 2011 06:02PM
This is true, they do come out the top. But they should function they same either way... I'm just not seeing the conflict. The ic shouldn't need any heat sink for the amps on my motors and a little screwdriver should be able to adjust the pot just fine.
Not arguing, just trying to make sure I'm not missing anything.
Thanks for the input
Re: RAMPS Question
June 19, 2011 06:43PM
> fine.
> missing anything.
You would have to solder the sockets for the Pololu's on the opposite side of the board in order to insert the chips. When you do, the trimpots won't be accessible. It's best to adjust this with the system running. Also, you should use heatsinks on chips to prevent them from overheating.
Re: RAMPS Question
June 19, 2011 07:47PM
I agree. Your headers need to come off. You won't be able to install them this way.
Re: RAMPS Question
June 20, 2011 12:02AM
Well thanks for bringing this up now rather than the headache later. I'm swapping them out now...
