layer shifting
November 10, 2020 08:36AM
hi i recently built my 3d printer and i have the layer shifting problem i kept reading about it but never understood the solution can someone pls help me and explain the solution
Re: layer shifting
November 10, 2020 09:05AM
Overheating stepper drivers, make sure you have a fan blowing on them . too much or too little motor current can lead to shifts. Belts or pulleys that are too loose. Binding carriages/bearings all contribute to layer shifts.
Edited 1 time(s). Last edit at 11/10/2020 09:09AM by Shank man.
Re: layer shifting
November 10, 2020 10:18AM
will adjusting the current of the drivers reduce heating?
Re: layer shifting
November 10, 2020 10:48AM
With proper adjustment of the stepper motor V-Ref current will keep the stepper motors running cool.
May I ask what you built in order to fully understand what your V-Ref Current adjustment current range should be.
Layer shifting can also be caused by Loose or tight belts, binding smooth rods with linear bearings ect... ect...
Edited 1 time(s). Last edit at 11/10/2020 10:49AM by Roberts_Clif.
Re: layer shifting
November 10, 2020 09:54PM
I'm using
ramps 1.4
A49AA stepper driver
17hs1352-p4130 stepper motor
is it ok if the stepper motor pulley and the idler pully hav different number of teeth and width?
Edited 2 time(s). Last edit at 11/10/2020 10:33PM by yoonus_rox.
Re: layer shifting
November 11, 2020 07:15AM
Is this stepper motor being as a dual Z-Axis stepper, if so is it wired in series or in parallel.
Almost forgot the most important question is the power supply 12 or 24 volts.
Max current on this stepper is 1.3 amps
V-Ref current center should be about 0.355 for 24 volts
V-Ref current center should be about 0.698 for 12 volts
Which axis is this stepper motor being used could you post a diagram of the how the gearing is being used.
