Gen 3 Extruder Problem June 22, 2011 01:52AM |
Re: Gen 3 Extruder Problem June 22, 2011 02:06AM |
Admin Registered: 18 years ago Posts: 14,177 |
Re: Gen 3 Extruder Problem June 22, 2011 03:13AM |
Re: Gen 3 Extruder Problem June 22, 2011 03:36AM |
Re: Gen 3 Extruder Problem June 22, 2011 03:52AM |
Name Value WindowPosition 700+0 Open File for Speed Activate Speed: True Add Flow Rate: True Bridge Feed Rate Multiplier (ratio): 1.11 Bridge Flow Rate Multiplier (ratio): 1.0 Duty Cyle at Beginning (portion): 0.75 Duty Cyle at Ending (portion): 0.0 Feed Rate (mm/s): 32.0 Flow Rate Setting (float): 40.0 Orbital Feed Rate over Operating Feed Rate (ratio): 0.5 Perimeter Feed Rate over Operating Feed Rate (ratio): 0.8 Perimeter Flow Rate over Operating Flow Rate (ratio): 1.0 Travel Feed Rate (mm/s): 32.0
Re: Gen 3 Extruder Problem June 22, 2011 04:39AM |
Re: Gen 3 Extruder Problem June 22, 2011 05:19AM |
Re: Gen 3 Extruder Problem June 23, 2011 02:13AM |
. I found that changing the settings in the speed page had little to no effect, but I went into the ramp page and changed the settings on all the flow related windows, and I now have an extruder motor that not only turns, but retracts when it should and best of all you can't fry an egg on it anymore!
Re: Gen 3 Extruder Problem June 19, 2013 07:27AM |
Re: Gen 3 Extruder Problem June 19, 2013 07:54AM |
