Will this kind of design work? March 09, 2021 12:21PM |
Re: Will this kind of design work? March 09, 2021 03:33PM |
Re: Will this kind of design work? March 09, 2021 08:25PM |
Want to share my Portabee. Its quite stable, I think because the 3 motors under the base which are heavy enough to hold the printer steady.
one of the design compromises we made in order to make the Portabee easily flat-packable (to an extent) and do so repeatably with as little hassle as possible was that the entire Y axis had to sit on the base rods, and as a result the stability is fully dependent on the stiffness of those rods. We opted for M6 for the base rods just so that there will be only one threaded rod requirement for the printer (z 'leadscrews' are M6 as well). With larger diameter rods the stability will improve.
Stability wise during use, we find that it is not a big problem unless the printer gets bumped or knocked over. Maybe much like a vase sitting there doing just fine until something bad happens (baseball, jumping cat, nunchuck etc). The base is heavier than the x axis (3 motors on the base vs 2 on the x axis) but yes, more stability is always a good thing.
We have tested a 'Y-brace' mod and it works pretty well. Basically this mod allows two printed removable braces to be attached to the (modified) y bearing holders, supporting them directly. The printer can still be taken apart fairly easily for packing if this is not made permanent - there is an option to permanently bolt the braces if the printer is not intended to be moved around, at least in its 'flat-packed' form.
Re: Will this kind of design work? March 09, 2021 11:46PM |
Re: Will this kind of design work? March 10, 2021 03:27AM |
Re: Will this kind of design work? March 10, 2021 03:28PM |
Re: Will this kind of design work? March 10, 2021 03:45PM |
MJLew
It might 'work', but it is unlikely to work well.
Frame rigidity is important so that, for example, the forces applied by the y motor reach only the bed rather than being shared by the bed and frame deformation and so that vibrations do not spoil the accuracy of hotend and bed location. Having no elements to prevent side to side deformation of the frame will allow the left to right movement of the extruder to cause frame movement.
If you do go with this design then you should consider grinding flats or holes into the rods to locate setscrews so that the forces of belt tension are not held by friction alone. I have had linear rods slide through the plastic when the force of a locating screw was insufficient to resist the belt tension.
I also see that the y belt is not parallel to the bed rails and so there might be some 'cosine error' in bed movement.
Having a bearing to locate the tops of the lead screws might seem like a good idea, but if the screws are not exactly straight, and most are not, then having the top and bottom restrained guarantees z-wobble-related artefacts.
The part fan arrangement is likely not to work because axial fans do not produce enough pressure to feed much air though a funnel. Consider using a blower-style fan instead.
If you want a printer for printing then I suggest that you consider the surprisingly good for the price Chinese printers, or the better but more expensive offerings from, for example, Prusa. If you want a self-built printer then you probably should look at the various designs discussed elsewhere on this forum.
Good luck!
Re: Will this kind of design work? March 10, 2021 03:50PM |
qrp-gaijin
I have a Portabee printer that uses a similar-looking design. I don't know how it compares to modern printers, but the Portabee sold more than one thousand units and a lot of people, including me, liked it. I'm currently fixing up my Portabee and printing out some replacement parts.
In the Portabee, the 2 Z-axis motors and the 1 Y-axis motor all lie in a straight line. This apparently provides enough stability, while still allowing the printer to be compactly disassembled and packed for transportation in a laptop bag.
[reprap.org]
Your design seems to place the 3 base motors in a triangular configuration, which may be better for stability since the weight is distributed across a wider area. There is a mod for the Portabee that adds some extra bracing legs to improve stability:
[reprap.org]
I've been recently updating the Portabee wiki page at [reprap.org], so you can find some more information about it (including full build instructions and downloadable 3D models for the parts) there.
Thanks for posting about your printer design. I had been wondering how to modify my Portabee, which uses a direct-drive extruder, to convert it to a Bowden-tube setup. Because of the similarity between your design and the Portabee design, it looks like the extruder and Bowden-tube mechanics in your design can easily be applied to the Portabee also.
Re: Will this kind of design work? March 11, 2021 09:20AM |
Re: Will this kind of design work? March 11, 2021 09:30AM |
Yes, it would be great to hear of your experience if you try building a Portabee or similar style printer. For now, I'm still tuning my printer parameters to get the best quality (hole size tuning is rather time consuming), while printing out replacement Portabee parts. Eventually I should have enough replacement parts to build a second, possibly modified, Portabee. Actually, I ordered my Portabee pre-assembled, so I never had the joy (?) of assembling it completely from scratch.Quote
kranlor12
I didn't know the Portabee before you posted this, what an amazing design, so simple but seems really useful. Unfortunately, I'm looking for a 20x20x20 printer and I'm not sure that will work with longer axis. I'll save the Wiki for a future reference project, as this seems to be awesome to put together, maybe make a workshop about it as a DIY cheap printer when I do it.
Because I'm not yet experienced with 3D printing and have not yet completed extensive calibration and testing of my printer, I fear that any prints of mine that I could show will not be representative of the maximum Portabee print quality. Instead, let me point you to some others' images and videos.Quote
kranlor12
I want to see the quality of this printer, maybe you can share few pictures of this?
Re: Will this kind of design work? March 11, 2021 12:39PM |
Re: Will this kind of design work? March 11, 2021 06:27PM |
Thanks for the feedback on the quality of the Portabee prints. Those prints are made with the Portabee printer, but they were not made by me -- the pictures are from other people who used the Portabee printer.Quote
NovaHuta
@grp-gaijin Your parts look pretty good. There does seem to be an under/over extrusion issue that is causing roughness. A little hard to tell from the pictures due to resolution but I'd hazard it is over-extrusion. Have you calibrated your extruder?
I have set the amount to 5mm and set a couple of marks on the filament with a distance of 5mm. Then I slowed down the speed to about 50mm. I hitted the Extrude button in pronterface and checked how far the mark has moved. Then I adjusted the spring compression in a way that exactly 5mm are extruded. I took me only two attempts. On my Portabee the springs are quite tight with only a small amount of compression remaining.
Re: Will this kind of design work? March 11, 2021 06:35PM |
qrp-gaijin
NovaHuta
As for my Portabee printer, no, I still need to calibrate the extruder. I'm reworking the mechanics of my entire extruder (replacing the original extruder block and printed gears with new self-printed replacement parts), and once I am satisfied with the fit of the new extruder parts, I hope to calibrate the extruder. I'm still a little afraid to be messing around with firmware settings, since the Marlin firmware on my board seems to be some custom version that was modified specifically for the Portabee, and if I mess up the firmware or the firmware settings, I'm not sure I would be able to restore the firmware to its original condition.
For example, [marlinfw.org] says that M503 should "Print a concise report of all current settings (in SRAM) to the host console", which should include the current steps-per-E setting, but on my board the M503 command does nothing. So something is odd about my firmware. Therefore, I have no way of knowing how many steps-per-E are currently configured, which makes calibration of the extruder a little tricky. On the other hand, I read about another Portabee user who simply calibrated the extruder in hardware, by adjusting the idler block tension to ensure that when the software sends the command to extrude 5 mm of filament, then the idler block tension is set just right so that the extruder advances the filament by exactly 5 mm.
[blog.tldnr.org]
Maybe I'm paranoid, but I would feel nervous about using a marker to make measuring marks on my filament like that. The ink from the marker will get sent through the hot end and might leave some residue on the inside of the hot end that could lead to a later clog. Or maybe I'm worrying too much?
Re: Will this kind of design work? March 12, 2021 11:23AM |
My guess is that you would need to make some changes in the design to improve the stability (a wider base, and a less-massive extruder using a Bowden-tube setup?) while sacrificing portability, and the changed design might then end up looking like the printer that you posted at the beginning of this thread.Quote
kranlor12
You got me really interesting in the Portabee, do you think it could be modified for a 20x20 bed? In terms of stability...
The only changes to the y-axis were to use longer steel rods. I simply got 300mm rods in place of the original Portabee rods.
Re: Will this kind of design work? September 26, 2021 01:11AM |
kranlor12
I'm currently trying to build my first 3D printer from scratch, I want it to have a lot of printed parts in order to reduce some costs (I have access to 3 more printers) and found an interesting design where I'm basing all my drawings (Kunprinter K86, see first attachment).
MJLew
