Over-engineering safety: Redundant thermistors, etc. April 04, 2021 12:51AM |
Re: Over-engineering safety: Redundant thermistors, etc. April 04, 2021 03:52AM |
Admin Registered: 13 years ago Posts: 7,000 |
// Use temp sensor 1 as a redundant sensor with sensor 0. If the readings // from the two sensors differ too much the print will be aborted. //#define TEMP_SENSOR_1_AS_REDUNDANT #define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
Re: Over-engineering safety: Redundant thermistors, etc. April 04, 2021 04:09AM |
Dust
Dust
4) marlin has hardware watchdog, if firmware crashes, the board is reset and heaters turned off.
Re: Over-engineering safety: Redundant thermistors, etc. April 04, 2021 06:27AM |
Re: Over-engineering safety: Redundant thermistors, etc. April 04, 2021 06:42AM |
Re: Over-engineering safety: Redundant thermistors, etc. April 04, 2021 11:03PM |
qrp-gaijin
separate Raspberry Pi (which I am already using to drive the printer anyway) could use a thermal camera to periodically take an image of the hot end and/or printer surroundings, and physically (e.g. via a relay) cut off the mains power to the printer if an abnormally high temperature condition is detected.
