3d printer
Posted by jaydip
3d printer
April 06, 2021 10:40AM
Connecting...
start
Printer is now online.
echo:Marlin 1.1.9.1
echo: Last Updated: 2020-06-20 | Author: (none, default config)
echo:Compiled: Apr 4 2021
echo: Free Memory: 5602 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echo: G21 ; (mm)
echo:Filament settings: Disabled
echo: M200 D3.00
echo: M200 D0
echoconfused smileyteps per unit:
echo: M92 X47.06 Y47.06 Z3200.00 E94.69
echo:Maximum feedrates (units/s):
echo: M203 X300.00 Y300.00 Z5.00 E25.00
echo:Maximum Acceleration (units/s2):
echo: M201 X2000 Y2000 Z100 E10000
echo:Acceleration (units/s2): P R T
echo: M204 P2000.00 R3000.00 T2000.00
echo:Advanced: Q S T X Y Z E
echo: M205 Q20000 S0.00 T0.00 X70.00 Y17.00 Z0.40 E5.00
echo:Home offset:
echo: M206 X0.00 Y0.00 Z0.00
echotongue sticking out smileyID settings:
echo: M301 P22.20 I1.08 D114.00
Setting hotend temperature to 185.000000 degrees Celsius.
Print started at: 09:20:46
echo:busy: processing
Error:Heating failed, system stopped! Heater_ID: 0
[ERROR] Error:Heating failed, system stopped! Heater_ID: 0
Errortongue sticking out smileyrinter halted. kill() called!
[ERROR] Errortongue sticking out smileyrinter halted. kill() called!
i make 3d printer using arduino mega,ramp1.4,marlin firmware i got these error i couldnot understand i check my hotend by given 12v exteranally it's woork but show error in printrun software i also configuration in marlin thermistor type.
can anyone help????
Edited 1 time(s). Last edit at 04/06/2021 11:02AM by jaydip.
VDX
Re: 3d printer
April 06, 2021 11:12AM
... is your heater heating? - could be, the sensor isn't reading the temperature?
Viktor
Re: 3d printer
April 06, 2021 12:02PM
when i connected with external 12 v it heating but connect with ramp i didnot
Re: 3d printer
April 06, 2021 12:05PM
VDX
Re: 3d printer
April 06, 2021 12:10PM
... check for correct pins definitions+connections and proper function of heater and temp-sensor ...
Viktor
Re: 3d printer
April 06, 2021 12:32PM
i checked many times
VDX
Re: 3d printer
April 06, 2021 01:05PM
... is it running? -- if not, then either the pin definitions/assignments/connections/powering not correct ... or wrong thermistor-type selected ... or something else ...
Viktor
Re: 3d printer
April 07, 2021 09:01AM
i also checked it many times
VDX
Re: 3d printer
April 07, 2021 09:32AM
... again -- is ist running/heating? ... is it measuring correct temp-values?
If not, then all your tests didn't lead to a solution ... you have to configure and setup the heater and temp reading (pins and thermistor type), so it can heat and measure the temperature ...
Viktor
Re: 3d printer
April 07, 2021 12:00PM
Post your configuration.h file or a link to it
Re: 3d printer
April 07, 2021 12:35PM
i set 5 in thermistor. my thermistor is not working what i do now??
VDX
Re: 3d printer
April 07, 2021 12:37PM
... give more info, so someone could help you ...
Viktor
