Depends what you have to bolt things to, rails is the answer, rods have much larger bearing blocks, though you can slim them down a little by printing housings(introducing any errors), the heavier it is the more chance of issues. I have one 12mm setup without support, pretty easy to make, I have supported 16mm on my mill setup, but all other printers are using linear rails, some using just one rail which I prefer, ok it's a big expensive rail but probably only the same price as 2 normal rails, and probably could be done with a smaller single rail, I think I've seen a few just using 1 rail.
