Help needed in setting up an inductive probe
August 04, 2021 02:03PM
Hi, I am using a PNP - NO inductive probe (LJ12A3-4-Z/BY 4mm 6-36V) in my Hypercube build. Previously I had a BTT SKR 1.4, but had to switch to a BTT SKR MINI v1.1. The problem is it worked fine on the previous motherboard, but I had to enable pulldownresistor in Marlin. However, my current board doesn't have such option (compiler spits out an error) and the probe stays in one logic state regardless of whether inverting option (in Marlin) is on or off and whether the led of the probe is lit or not. Is there a way to solve this or do I have to get a different sensor/board?
Re: Help needed in setting up an inductive probe
August 06, 2021 02:08PM
Simplest way is with 2 resistors
probe wireing
October 11, 2021 05:47PM
Hi, i have problem with inductive sensor, i change the z offset and save the bed matris but again some where are very close and some where are far , how can i fix it? I use cura for printing
August 16, 2022 11:16AM
Did you get it working? I have the same problem
