Hi, I have an inductive PNP-NO probe, which I connect to a 12V power source and through a voltage divider (12-->3,3V) to my BTT SKR 2.0 board. When I measure voltage on the signal pin it says 0 when there is no metal near the probe and 3,3V when there is. However, when I plug the signal wire into the z endstop in the board, the measured voltage without metal is 1,5V not 0. I believe this causes the probe to be constantly on. Is there anything I can do if my board doesn't have a pull-down resistor or do I need, a normally closed probe?
