CoreXY: Non-matching MGN carriages on either side of Y?
December 01, 2023 08:24AM
I'm buildling a CoreXY and improvising a little as I go along.
I bought a pair of (expensive) MGN12Cs for Y axis carriages and an MGN12H for X axis carriage (working from HevORT BOM), but the smaller carriage would actually suit me better on the X axis. If I swap it around now I'll be left with one MGN12C and one MGN12H for Y axis.
Do you think this is a big deal? Will the slight difference in mass cause some vibration or other problems related to asymmetry, etc?
Edited 1 time(s). Last edit at 12/01/2023 08:25AM by DailyFrankPeter.
Re: CoreXY: Non-matching MGN carriages on either side of Y?
December 01, 2023 04:17PM
Hello,
It shouldn't be an issue if you adjust the screw holes of one of the Y ends to the position of the H carriage. This assuming both carriages are identical of thickness.
Aside from that, if you can use the H for the X axis it will probably be less of hassle and make more sense to stick to your orginal plan.
