Hi all. I had built a Huxley a while back, all was good but decided to make something a bit bigger. I built an i3 clone using all of the components from the the Huxley. Ramps 1.4, Nema 17 motors, same belt size and pulleys.... I tweaked my configuration h and all worked fairly good. I decided to add an inductive probe for bed leveling and everything went sideways. After several tweaks the movements, X,Y and Z are 1/2 what they should be. I didn't knowingly change anything that should affect that. Using the LCD to move has the same result. I went back to the original configuration h and still have the same movement issue. Any suggestions? Should I start config h from scratch? If so, what sample file would be best to start with?
Thanks in advance.
