Hello, I'm trying to make a new sensor type to measure the water in a water tank for my clay 3D printer, any suggestions as to how I should go about making this? I tried to make a duplicate of the thermistor sensor and haven't had any luck.
I've built a capacitive water sensor before now. I used a coil of insulated wire running insure the tank and measured the capacitance between the coil and ground. Measuring capacitance using a microcontroller such as an Arduino is straightforward.
Edited 1 time(s). Last edit at 07/13/2024 04:26PM by dc42.
